1997 evinrude 115 hp v4 mdl#e115tsxecm sr#g-04405147
vernon hunt
im having trouble with the motor to throttle up under pressure. starts up and runs smooth but wont excelarate. i've drained all the gas from on board tank, put in fresh fuel with fuel conditioner,installed new spark plugs and wires,also checked fuel filter and it was clean, the bulb is tight. any ones help on this problem would be great.
schematic
Re: 1997 evinrude 115 hp v4 mdl#e115tsxecm sr#g-04405147
Does it die when you accelerate?
Check compression, spark and fuel pressure. If all is fine, clean carbs
vernon hunt
thanks for answering. it didn't die it just wouldent throttle up i'll check what you said thanks again
