9.9 Gradually Running Worse
Novy
Hey all! I'm in the process of getting some boat motors going for my mom's boyfriend (yeah....I plan to use it too), and am thinking I am chasing a spark related issue on a '74 9.9 Johnson. This was a $40 garage sale find, the guy was told by a shop that it needed a waterpump. It had not been run in over a year, but the guy claimed it ran ok. Because it was between this and a 1965 merc 110 freebie with an issue that was unknown (been passed between several people and info forgotten), I elected to start on this one since it was said to run. I pulled the bottom leg and found the pin that holds the impeller to the shaft had somehow come out of place. I cleaned it all up, reassembled and went on trying to get it running. It took a long time to get it going and was hard on the arms (for some reason it feels unusually difficult to pull), but I did prevail. It seemed to run poorly so I got new plugs and tore down the fuel pump and the carb (which was oddly pristine inside). I also did a compression test and got numbers around 65# (3 pulls). After a little run time to clear up it seemed to improve but did not idle well and seemed hesitant at higher rpm. I noticed some bubbling at the cylider head and found some loose head bolts, brought the compression to around 75#. I decided to take it out fishing to get some run time on it and see what I would come up with. Off the bat it ran and got the boat moving ok, though slow for a 9.9. It seemed best at about 3/4 throttle. At WOT it seemed to surge in short cycles of about 2 seconds, it would sound to run smooth and pick up a bit of speed and then kind of sputter. I ran it about 10 minutes till I got where I was going and then left the trolling motor take over. After an hour I decided to try the other side of the lake and had a heck of a time getting it running. When I did, it seemed to have reduced power. Getting across the lake took about 5 minutes and I shut it down again. The bugs on this side were terrible and after about an hour I decided to go back to where I left off on the other side and troll back to the boat launch. This time getting it running was a nightmare, it took putting it in gear at full throttle to fire up. Again, power was further reduced and gradually got worse as I went, to the point that at WOT it was barely at a fast trolling speed.
After returning home I pulled the plugs and found one to look maybe a bit on the rich side while the other was still quite shiny and wet (#2 cylinder IIRC). I thought maybe I had lost compression so did another compression test, this time coming up with between 75-85# through my 3 attempts. Grounded the plugs and pulled it over with the lights out, both plugs look to spark ok. Pulled the flywheel and found #1 points to be around .025 and #2 to be .020. Both sets of points look ok, so I set #1 to .020, and that is where I left it pending some input. I'm wondering if I should try condensers or what the most logical next step is.
At this point I will probably not invest a whole lot into it. After getting to this point I decided to give the merc a try to see if I could find the unknown issue with it. Had to rope wrap the flywheel as the recoil is shot. Damn thing fired up in 3 pulls and ran like a top despite not having run in over 3 years. The issue was immediately apparent as it was not pumping water. Pulled the bottom leg and found the impeller to be disintegrated. I'll be proceeding with this engine for now but trying to get the Johnson going as a spare if it can be done cheap enough.
Daviet
Re: 9.9 Gradually Running Worse
It sounds like you still have a problem with the carb. It sounds like the high speed jet might be plugged or restricted.
By the look of the plugs, the one on the right side could be washed clean by water. If the head gasket was loose, I would install a new gasket. The head gasket could also be causing your high speed and hard starting problems.
You need to check the spark with an air gap tester, the spark needs to jump a 7/16" air gap and be bright blue.
OptsyEagle
A couple thoughts. You do need to check spark with an external spark tester and ensure it can jump at least a 3/8" gap and more importantly, that both cylinders are firing. Secondly, for some unknown reason, that motor hates champion spark plugs. Put in some NGK B6HS plugs and see if the surging goes away. Champion plugs made mine surge and bog, surge and bog. Obviously one was intermittantly firing. The NGK plugs made that problem go away. Many others on this site have had similar issues with Champion plugs on the 1974-1976 9.9/15Hp series of motor. All other motors are OK but the type you have has a cylinder head that causes problems with the plugs that OMC never really figured out, if you ask me.
I would think seriously about changing the head gasket as well.
tanuki
Ditto on the NGK plugs....I use NGK B7HS plugs in my 1975 Rude 9.9
tx1961whaler
I had a 1975 9.9hp fairly recently that gave me fits. Good compression, great spark, clean rebuilt carb, but would crap out. Problem was with the crank seals. The spark plugs looked like yours do.
raczekp1
hi.i think compresion is to low.compresion should be over 100psi/cyl
last year i did rebuilt 15 hp made in 1979, new rings instaled.after rebuilt i got 125ps/cyl.
but before i started to rebuilt compresion was 80psi/cyl
after rebuilt motor start first pull.
i got also 15hp evinrude made in 1996,compresion was 110/cyl.maotor also start first pull.run fine,
now i got 15hp motor as a rebuilt project.upper cylinder 110psi, bottom one 60psi(broken ring, but not scored cylinder)
so in my opinion 110 is fine.motor will be ok for few years.i think will start first pull also
Novy
Thanks for the input so far.
-I don't think the carb being dirty is an issue at all, as I pulled it apart an it was spotless. I went through the process of cleaning the jets anyway to be sure.
-The bit about champion plugs is interesting and those are what I had installed.
-If we are looking at crank seal, head gasket, ect I would imagine the engine will likely be scrapped or sold for parts since the merc is looking like it is going to be a solid motor.
OptsyEagle
Try the NGK plugs. B7HS for normal running and B6HS (one range hotter) if you plan to do a lot of trolling.
Don't scrap it for either of those two problems. I am sure someone would buy it cheap. The head gasket is only about $20 and maybe 10 bolts to replace (should resurface the head by sanding it down with some finer grit sandpaper on a very flat surface). For crankcase seals, the bottom one would require the head to come off but the seal itself is easy to replace and only about $5 and the job would probably take 3 or 4 hours although many here could probably do it in an hour and a half.
Anyway, good luck to you with your motors.
