New to forum and new to boating. Intermediate mechanic. I have read several posts here thus far and finding it all very helpful. I have recently purchased an 87 searay with merc 4.3 V6 (IV thunderbolt ignition). Motor ran when I bought it but didn't realize it had a problem until out on the water and at times boat would not get fully up to speed at times (not over 3000 rpm at full throttle) and seemed like it was not firing on all cylinders. I have now since changed the plug as a couple were fouled and #1 plug had no gap. Wires, cap and rotor all look good. Ignition sensor was rusty so I cleaned it up. Motor started but idled a little roughly so checked out the timing and it was off. Checked distributor ( gear looks fine, not worn) Set motor at TDC at compression stroke and reinstalled distributor with rotor and cap pointing to #1 cylinder. Also base timed it at 8* BTDC. Engine started right up and ran smoothly. Went back out on the lake and on the first run it ran OK but still would not get up to top speed (between 4400 and 4800 rpm I think???) After that it just didn't run right at all and would not run over 3000 rpm at full throttle and was sluggish. It would however idle OK and start up with no problems. I brought it home and was going to work on it some more today and now it won't start. Not sure what is wrong. Could the igniton sensor be part of the problem? I know it is a long post but trying to give a little history. Anybody can help me out I sure would appreciate it. Hope I haven't created any other new problems with my limited mechanic abilities. :redface: This looks like a great forum...glad to be a member now. If anyone out there has any ideas that would be GREAT! Thanks.....hopefully posted this correctly
