elcapitanmas
- Aug 25, 2012
- 4
Hopefully someone can provide some input as I don't want to just start replacing parts for no reason.
I recently installed a 2000 merc 25hp bigfoot on my tracker grizzly.
motor starts up and idles better than any motor I've ever owned, runs awesome (as much as I've run it so far, I rarely have to go far for my fishing spots.)
Into and out of gear, back to neutral, motor runs fine, no sputtering, coughing, sneezing, NADA.
I have been out trolling for the past couple weeks and after trolling for a couple hours and go to WOT the motor will eventually hiccup and then die. I am unable to restart it and it seems as if the motor is flooded at that point.
When I purchased the boat, I didn't realize that it had 24 gallons of gas in it
which at the most is a year old. I added ethanol treatment as I know its going to be a PIA to empty out the 24 gallons if it is indeed bad gas.
I am headed out again tonight and will be running an external fuel tank to see if I have the same problem, if I do, then obv its the gas and I'm hoping that a fuel water seperating filter will do the trick so as not to waste over a hundred gallons of gas.
my other thought was that the carb may be gunked up, but I am under the assumption that if that was the case, it would run like crap or not at all when trolling for hours at 1.5mph.
Any help is greatly appreciated.
E
E
