I've got a 1987 90HP Evinrude VRO motor, and I've done the disconnection of the oil injection, as described in a link on iBoats.
I capped the oil input to the VRO pump, removed the two wires from the tank to the engine, and removed the oil tank, hose, and wires. Now, my question is in regards to what the capped oil input to the VRO pump will do. As I understand the system, the fuel is routed through the VRO pump, which senses the flow and adds appropriate oil amounts, when in service. Since the fuel is routed that way, I can't just run the fuel line direct, bypassing the VRO pump, and to do so I would have to install a stand-alone fuel pump? How would that get connected? Would I then just cap off the vacuum port that previously provided the VRO pump with it's pumping pulses, and route that to the stand-alone fuel pump?
Can someone help me out on this?
Can I just run the motor, as I have it setup now, with 50:1 pre-mix in the tank?
thanks
thanks
