Re: troubles with motor
I have been trouble shooting my '82 175 Evinrude as the other day As soon as I reached full throttle it shut down. It took a moment or two but I noticed the primer bulb was flat. Knowing that means there is an obstruction up stream, I finally found an acorn shell in the primer bulb caught in the spring. It was not before long head scratching sessions as to where the clog was. Good news is the problem is solved, bad news is I have to vacuum out the gas tank. Anyhow, Are you sure your getting fuel to your motor?
