alpha one gen 2 top cap bearing
r_bankston_3
Hey im new here..Can anyone possibly tell me the number for the bearing and race in the top cap.. mine froze up and i cant read it and i would like to pick one up at a local bearing supply. Thanks..
Don S
Re: alpha one gen 2 top cap bearing
Not every Alpha I Gen II took the same bearing. So without a drive serial number, you can't even get an accurate Merc PN for one.
I also can't imagine that bearing freezing up and there isn't something else wrong somewhere that you aren't aware of.
r_bankston_3
0w562496.. Its a 2006 model 1.81 gears.. The bearing spun... Its was run low on fluid..
ktbarrentine
Then you most likely have other drive problems, too...(including metal in the lower gears). just sayin'
r_bankston_3
The drive oil that was left in it didnt appear to have any metal in it.. I pulled the the top cap and found this bearing. i removed the yoke shaft, seals, double bearings, and drive gear and driven gear.. all is well except this cap bearing..
Ayuh,... Welcome Aboard,.... Do ya have the manual to shim, 'n set the rollin' torques,..??
The lower should atleast be torn down, 'n Cleaned...
Any ground metal from the upper, falls into the lower....
r_bankston_3
Yea i have the manual.. and i have a new set of double bearings.. And im gonna set the rollin torque with an old driveshaft i have..I jus need the number for the top cap bearing so i can purchase it locally.. thanks for the replies guys..
muc
"Retired" Association of Marine Technicians...
32575T1 is the MerCruiser number for the bearing
18-1179 is the sierra marine number ---- Napa can use that number to cross reference.
32563A1 is the shim kit for upper bearing
18-2282 is sierra
35980A1 is the shim kit for double bearing
18-2292 is sierra
I’m guessing you already have the o-rings and seal that you will need.
It would be pretty foolish to not replace them while it’s apart.
r_bankston_3
Ok thanks man.. I didnt know the parts store could cross the merc number or sierra number.. i always thought you had to have the number off the actual bearing.. But i thank you.. Thanks for the reps guys
