Oceanpro 225 compression test
hammergoss
:confused: I performed a cold compression test today as motor has been acting up. Rebuilt carbs new gaskets, floats etc. Readings were 110'105/95 other side 110/105/110. The confusing part When testing all cylinders the engine would stop turning as normal except for the lowest reading cylinder. The engine would continue to turn as long as I held the key turned.
Hence my confusion. This all started with a idle issue and bog down on take off. On plane engine ran out good and was smooth.
1995 ocean pro 225
boobie
Re: Oceanpro 225 compression test
Did you have all the plugs out when doing this test ?? Are your battery and connections in good shape.
hammergoss
Yes, all plugs were out. The other five cylinders after the motor turned over about three times I had to release the key and return again. Just that one cylinder..
