Phishnvdub
- Jun 16, 2012
- 46
Ran my motor in a barrel tonight for bout eight minutes. 1975 Chrysler 25hp 255HA. Mostly idling with a couple blips of throttle with the neutral warm up switch out so the prop was not spinning. The barrel was tilted back a little so everything floating was concentrated towards the front of the motor. Barrel sprung a leak when I finished at the bottom, is why the water is so low. I had the hose on in the bucket the whole time so it always had water going thru the cooling system. Anyone know what oil that is? Unburned fuel? I remember there being a little black around the inside of the barrel after running it before, nothing like this I can recall. Curious if this is bad?
