Bama Hound
- Jul 30, 2012
- 47
I used the method in the sticky file to time my motor, I think. First of all I can see my timing light at night But I can't see light in the daytime with the sun out. So any help I can get before dark will be greatly appreciated. I need to begin work at zero dark 30 I will tell you what I have done and if anything is wrong,please advise. First of all on the air horn of the motor it says 28 BTDC correct double check here, please. Now in the Seloc book it says max advance 27-29 BTDC correct double check here, please. 24 would be right number to shoot for, right? O.K.(28-4) Now the other night I put motor on fast idle (not running) as far as it would go. This opens butterflies all the way,correct? Now with 2,3,4, plugs removed from holes w/ plug wires attached, I used alligator clips around each plug and all were hooked to ground. #1 plug out of hole w/gap tester attached to it was also grounded. The clip for the timing light was attached around #1 plug wire, which is top cylinder on starboard side, correct? Now with ignition to "ON" I use remote starter to turn motor. Timing was 18 BTDC. Now before I go any further I have to address the rubber stop referred to in instructions. I don't have a rubber stop anywhere. What I have is a Phillips head screw 1/4-20 NC under my flywheel with a nut behind it so as to lock after adjustment is reached. Now here is the magic word, I ASSUMED this is the stop for the full advance, is this correct? I was happy that it was because I loosened the locknut and screwed the screw "IN" and timing mark moved higher. When I got to 24* I stopped and tightened the locknut. After I tightened the nut I rechecked with light to make sure I did'nt move screw when tightening. Now while this is going on I am making sure that the "arm" is against screw when using light. You can't "wire it" the arm to anything as ypu can't get to screwhead if you wire the arm to it. Now instructions say idle will take care of itself. It threw my sync off so I removed cable and adjusted to where lobe is on centerline of carb arm. Now I have it re- adjusted where movement of throttle arm starts opening carbs. Now I reattach cable. Cable is in neutral,
Now the next day I back boat into water far enough to come 3-4" below exhaust skirt. I adjust tilt trim so motor is approximate angle it would be in during operation. Boat is still on trailer with truck in front. I get on board and start using normal starting method. Always has been "cold nature d" have to hit solenoid several times nothing new. It gets to operating temp and I put it in forward and try to advance throttle. It spits and dies. Repeat several times with same result. Here I was expecting to either blow all the water out of the lake or start shoving my truck up the hill. I am devastated, I am really lost. Clueless as what to do now.
