- Jul 7, 2010
- 15,109
I'm in the process of doing the head gasket (1st timer) and have got everything taken apart. Head is about to go to the shop to be machined (valves too) and I think THIS is the gasket set I need. Correct?
Also - in that set are two gaskets that go under the rocker arm covers (if I've got it right). Should I change those since I have the manifold (gee, ain't that heavy?) off right now? Or is it a "if it ain't broke" part?
Suggestions welcome - thanks as always.
