catfishcarl99
- Apr 25, 2012
- 723
Ok i got a Q for the leak repair fellas. ok, sat night me and a buddie were fishing and long story short after 6-7 hrs on the water i had a few inches of water in my hull. i had recently repaired a hole with some 2 part epoxy while i was restoring floor. its holding strong. today i filled hull with water while it was dry. well good news is none of the 500 rivets are leaking. thought for sure thats what it was.
bad news. its this rib along keel.
the rear is welded along the stern. it runs the entire length up to the bow to tip of rubrail out of water line. mt Q is what do i do to stop the leaks? my best idea was to wait till end of season and give it a couple weeks to get good and dry and run a bead of the marine sealent along its entire course on each side. any better ideas asside from welding?
also this small crack. wish i had found that before i sealed the floor up. cant get to inside i dont believe. would have repaired that with the epoxy too inside and out.
