Charging battery from a 1982 Merc.50HP
Charlie61
Re: Charging battery from a 1982 Merc.50HP
yes if it's ele, start
Charlie61
Thank you.It is Elec. start
A quick way to check is frist check voltage at battier likly to about 12.5 volt dc , then check voltage when motor is running it should be about 13 to 14 volt. DC anything above normal voltage not running.
have fun good luck boating
