boattechlm
- Aug 21, 2012
- 7
i need help with this motor 2000 225 hp FICHT
does not want to start cold
fuel pressue and fuel is good, spark is good also. compression good,
voltage while cranking good . new optima battery
i can remove silencer on intake and spary fuel into intake
motor will start and run good
no codes, no horn, no lights. after run up to temp if you shut motor down
it will restart if done right away. if it sits for 5-10 min very hard to start
if it sits overnight will not start
any help would be great
thanks
thanks
