overkillthemighty
- Jul 6, 2012
- 13
This all started with THIS thread. I decided to take the plunge and rebuild the old beast myself. I could probably get another powerhead and swap it if I looked long and hard enough, but I just feel like a miserable excuse for a human throwing such a beautiful thing away. I have all of the pictures of the boat HERE if file uploading won't work as well as the actual blog i have been keeping HERE.
I have a couple of concerns to start with, and I want advice on how to move forward from here. First off is the distributor.
As you can see, there are three wires coming out of the distributor that are in really bad shape. I was wondering what they do, if it is better to try to save it, or if I can get a replacement for a reasonable price.
Next is the reason I took her apart. The compression was low and I was trying to check for how much damage has been done. Unfortunately the flywheel removal process did not go well at all. I tried to make a bolt-on puller for it, but it destroyed it (1/2 inch steel!), so I tried an automotive puller and nearly busted that. Then i tried heating it with the puller going. The propane torch didn't work, so I used an oxy acetylene torch to heat it. I was about to break the puller, so I wacked the slide from the bottom (I had unbolted the flywheel so as not to bend it) and after about 10 hits it finally popped off. I know that can mess up bearings and seals and such, but it was the only way to get it apart. What do I need to check for damage/how, and are there any precautions I need to take?
Finally are the actual pictures of the cylinders and pistons. It looks to me like a case of bad rings, but I really know very little about this subject and will defer to the experience of this forum.
