Re: will this wiring diagram work
Gauges are not powered from a fuse panel. They get +12 volts from the "I" terminal on the ignition switch for an I/O or the "A" terminal on the ignition switch for an outboard. You show a 60 amp fuse in the +12 volt lead from the battery to what appears to be the positive bus. The wire in that circuit must then also be capable of carrying that much current or it will burn up before the fuse blows. The switch for the NAV lights must be a three terminal (ON-OFF-ON) with a diode or a six terminal (also ON-OFF-ON). An option is the push-pull type switch made especially for NAV lights.
