sodbrother
- Aug 6, 2012
- 1
I just purchased my first boat. 1998 Cobalt 232, with Mercruiser 7.4L, Bravo one Outdrive, 21P prop...
I am a decent auto/motorcycle mechanic but I am new to the boating world. I checked the engine oil and it looks full and really clean (not black) I changed the Outdrive oil and it looked clean with no water.
Here are my questions.
1. Was told to replace plastic freeze plugs with brass, is this a good idea?
2. My speedo is not working, Did some research... pulled the fitting off the middle of the outdrive and the hole in the bottom of the outdrive is clear, where is the next break in the line where I can check for blockage? Do I need to pull the gauge?
3. When I am WOT cruising about 4K rpm and I cut the throttle the boat turns hard to starboard, is this normal?
4. How do I check the water pump impeller?
5. Any advice on things to check? Common problems?
