Schmitttim
- Aug 20, 2012
- 2
Hi all! First post here and I hope it's in the right spot. If not, please let me know where it should go.
I'v had this engine for a year now and would really like to get some more detailed info about it. I'd also like to figure out if I can make the power tilt/trim work again. The engine had just had a major service ($800) done before I got it and it runs perfectly. They upgraded the ignition and went through the whole lower end as well as a cleaning and adjusting of the carb.
I have a few questions.
1. I believe the engine is a 1967 based off the 100783A model number on it. Can anyone confirm that?
2. I have talked to a few people and they have said that these engines did not come with power tilt/trim. That would seem accurate to me because of how shoddy the wiring is for it. Can anyone help in telling me where I could get the parts to rebuild the power trim/tilt? Even help on telling me where it came from would be awesome. There is obviously some parts missing. This is a beast of a motor to lift by hand for me. There is no way that my wife could do it.
3. The tach is not working at all. It sits at about 1k rpm with the engine running. Only varying slightly with the actual engine speed. It would seem that the tach and the new ignition are not compatible. Any ideas on how to check that?
4. How can I run this engine safely with it out of the water?
I have attached some pics for help with some of these questions. Thanks for all the help.
