hi;
i'm really hoping someone can help me. the engine has 44 hours on it, but it sat for a long time. the engine runs great for about 2 or 3 miles and then it will shut off like it is out of gas and won't start. if you take the water filter off empty it and put it back on, prime the filter by turning the key on and off a few times it will start againg and do the same thing. there is no water in the fuel (tank drained and vacuumed out). it seems like an air lock. the last time it did it I opened the gas cap to see if it would start and it wouldn't. the only way is to empty the filter. has anyone else had this problem? my boat has a shut off valve at the tank but i don't know if it has a anti siphon valve. where would the siphon valve be located. and again it run perfect for the time its running then just quits like it's out of gas......HELP
thanks
Ray
thanks
Ray
