eastcoastchris
- Aug 20, 2012
- 3
Hi,
New to the forum ... first post.
I picked up a 15hp 1988 Evinrude from a local guy. I saw it running fine at his place. Even disconnected it and had it laying down for a bit and then re-hooked it up and it ran fine. Started first pull both time.
So, I get it home and one my boat and it won't start at all.... so I brought it up to the garage and put it on the stand.
Next morning I put it in a bucket and try starting... works first pull... Runs fine.
Take it down to the lake (2 minute car ride) with the motor laying on its side in the back. Hook it up and then nothing.... no fiddling will get it to run!
Take it back up. Tested spark... good. Fuel seems to be getting to the carb fine. Bulb is hard after pumping.
Guy said he resently did a fuel pump, plugs, and carb kit install.
Able to get it to start and run for 5-10 seconds by spraying fuel into the cylinders.
Took the carb apart and it was sparkling clean. Float / needle valve seemed perfect. Blew out what I could with compressed air.
Was able to get it started up after this fairly easy.... ran it for a bit. Then removed it and laid it on its side and back (carrying handle up) for a bit (10-15 minutes) ... hooked it all back up and then it totally wouldn't start again!!!
Went out this morning before work.... gave it a pull and it started right up. Seems to need some adjustment, but was running okay... missing/sneezing a little bit.
So, what would cause it to get messed up when it is moved/laid on its side/back?
Baffled and have tried most everything.
Thanks for any suggestions!
Cheers,
Chris
Cheers,
Chris
