Re: 77 Johnson conversion pee hole
Lots have done it, run a search and you will find several posts on it.
If done like the factory, the tell-tale is before the thermostat, it shows that the water pump is pumping. You can still have an overheat condition even if the pump is working correctly. A defective thermostat(s), head gasket, gromets a probably several other things.
