shifter nut
- Feb 25, 2012
- 27
well i replaced my manifolds and heat risers , head gaskets, head bolts, intake bolts, thermostat, all coolant hoses, fresh water pump, ...i posted a while back and with previous work done except for the manifolds,risers...engine had hydrolocked and broke the starter...since that post ive replaced the starter and the manifolds ...ran my boat on muffs and in a tube of water for good water supply. let it run about 25 minutes shut it off rechecked all my clamps had a few water drips...started boat again let run shut down checked oil was good. restarted engine let run again for another 20mins or so noticed engine oil pressure was jumping around..checked oil was milky white...what am i missing.....5.7 liter inboard
