73 25hp johnson breaking pins
we have 73 25 hp johnson outboard . i hit a rock or something it was in idle it shut the motor off and ate the prop .took the prop off and the pin was bent bad . replaced the prop and pin took it back to the water before could get to top speed it woulld break the pin again . done this 4 times took prop off and put the old one on and it bent it again. can someone please let me know what is going on?
F_R
Re: 73 25hp johnson breaking pins
First question: Are you using the correct pin? It is supposed to be stainless steel.
Another possibility is a worn out clutch dog. That will make it come out of gear, rotate 180 degrees, and slam back into gear. The violent jolt can break the pin. ESPECIALLY if you aren't using stainless pins.
A very badly worn hole in the prop shaft or slot in the prop will be hard on the pins too, but it would have to be terribly bad to cause the problem as you describe it.
boobie
What type of pins are you using ?? Stainless or brass ?? Is the prop nut tight when you put it back on ??
i have tried brass and stainless both kinds broke.it had jumped out of gear
before i hit the rock but would not break the pin
nwcove
jmo, but if it was jumping out of gear before the rock.....the rock put the last nail in the coffin for your clutch dog.
boobie
You didn't say anything in your first post about jumping out of gear. Agree with nwcove + 1. One should tell all when posting a problem.
i thought it was just another problem since it had not broke pins before. well, i tore into the gear casing and found numerous problems. someone caulked where the o rings was . the shift rod was bent and few other things. the front and reverse gears looked good though . I am going to replace alot of the things in there including clutch dog and cradle. thanks for the advice.
