1988 25hp starter motor
Apehanger
Can anyone tell me how to remove the starter motor from an Evinrude 25hp 1988 model please?
The motor has been engaging for a couple of seconds before dropping out - although it still spins.
I removed the two through bolts, the bottom casing fell out,along with the springs and bushes.
However the remaining assembly is still too long to be able to remove it from the 'holding ring'
I really can't figure out a way without removing the carb and, perhaps, even more :facepalm:
boobie
Re: 1988 25hp starter motor
Try shop.evinrude.com and look up your mtr. They have good parts diagrams. You pull the bracket and the mtr off first.
Apehanger
WOOPS!
Amazingly that is exactly what I did just over half an hour ago!!:eek:
I spent ages looking over the casing but couldn't work out how it was fixed.
I thought it seemed impossibly difficult the way I was doing it DUH!
Oh well, relevant part printed out and looking forward to finishing work today so I can get on with it.
Thanks for your reply :)
