moonshiner1
- Aug 19, 2012
- 1
I've had a 89 Mercury 25hp long shaft since spring and haven't been able to get the thing to run right. I haven't put a ton of time in it recently as I have been busy with other projects. I have replaced all seals in the carb, as well as installed a new fuel tank and line. It fires on one to two pulls and runs for a minute or two after that. I have tweaked the adjustment screw on the carb, with little to no improvement. It runs, but dies after a minute or two. Takes even less to die from anything above an idle. It appears to be flat out running out of gas. Like it starves itself out. I can hear when it is about to happen, and to keep it running, I can squeeze the ball and get it to go for another minute or two. At this point I'm just hoping there is a simple fix because it seems like I'm so close to having it work. Any thoughts??
