Patrick in wa
- Jul 23, 2012
- 12
First I need to mention how glad I am to have found this forum. Everything I have learned about my outboard and outboards in general has come from this forum, so thanks.
I changed my lower unit oil yesterday because I have been having trouble getting it to shift into reverse. I noticed the used oil was lighter in color than the new oil. Is that what "milky" oil looks like? I thought "milky" meant that it would have streaks of white in it, but mine was a solid color.
My manual says to use type c oil. Hypiod 90 is the correct replacement for manual shift units right?
When at the marine store I grabbed gaskets labeled OMC. They are black o-rings. When I changed the oil the plugs where seated on white plastic washers not black o-rings. Are the o-rings the correct replacement or do I need to find the white plastic washers?
63 evinrude 40hp, 40353d
Thanks for your help
Pat
Pat
