Re: 1993 9.9 johnson throttle handle adjustment
are you using the idle adjustment knob at the end of the tiller handle?...you may have to adjust the throttle cable tension some if it has stretched, the idle adjustment knob pulls or pushes the cable in small amounts to set the idle speed you want
