The owners manual and the repair manual and the repair manual are no help to me.
What is the "gear lube" and is it different than the "lower gear lube" and where do you check/add it on a 4.3 2007 model with 190 hp.
It's not the oil (top right of motor), it's not the trim fluid (down at bottom, to the left of the motor itself), it's not the power steering (down low on the front right of the motor).
I believe is the spot/access/cap/reservoir labeled "lube" the is in between the oil and the power steering on the front mid level right side of the motor.
Is that correct?
I have the bottle of "lower gear lube" that the previous owner gave me, and am wanting to confirm that "gear lube" and "lower gear lube" should be the same thing. He did his own service and took maticulous care of the boat as far as I can tell.
I don't find any place on the motor labeled for "lower gear lube".
Any thoughts are appreciated.
Is that correct?
