Own a 87 Sea-swirl runabout I/O OMC cobra 3.0 with a Rochester 2 bll carb. Newly rebuilt carb, ran for about an hour yesterday in the yard at varying rpms, didn't run perfect but good. Today, cannot even get it started. When we attempt to start it, it seems starve of fuel, sputters and shuts off a few seconds later. Checked fuel supply, alternative fuel supply, filters, points, condenser, fuel pump, carburetor, fuel lines are not plugged, cap and rotor are new, plugs are new and gaped. Fuel pump is new, coil, interrupter switch, starter, and alternator. Previously had salt water in fuel supply and have tried to repair all affected parts due to salt corrosion. All performed electrical tests have resulted okay. If you have any further questions about specifics or advice on tests or functions to perform, that would be greatly appreciated.
