AlumCanuck
- Mar 30, 2012
- 14
The issue:
Motor starts great, runs great, has plenty of power, but only for about 10 minutes. At this point is begins to missfire, then starts to struggle and will bog down. The motor will still idle perfectly, but bogs down when you start to apply throttle. Applying the choke has no effect when this happens. Staying at WOT will make the motor stall. If you push the motor until it stalls it will take a few minutes before it will start again.
This problem is very consistent and happens every single time at about the same point. Basically once the motor gets to operating temperature it conks out.
What has been done to the motor:
Previous owner included it with a boat I purchased basically for free because he was tired of trying to fix it. He had it in a shop several times and they were not able to correct the problem. He said they had replaced the coil.
When I first got the motor I suspected it was running hot, so I replaced the water pump and thermostat. Found some zebra mussels in the cooling system upstream of the thermostat. I think I got them all out and there appears to be more water running through this motor now. Also repaired an issue with the accelerator pump in the carb, though this is unrelated to this problem.
Today I put on a clear fuel filter between the fuel pump and carb to so I could check for vapour lock when it died. I also used a different fuel tank and line that I know to be fully functional. As usual, the motor started to missfire and quite after about 10 minutes. It had plenty of fuel pressure and no sign of vapour lock.
I have done a ton of reading and am no closer to finding the problem. Getting frustrated....I'd like to confirm it is a problem with the electrical system, but I don't think I can perform this test once the motor quits before it magically comes back to life again.
Anyone had this issue with this motor? Any ideas? What should I do next?
Help?
Help?
