Bimini top
t8764
I have a 2006 tahoe Q6 with the factory bimini top and I lost a part for it that I cant seem to find. Here is a picture I anybody knows where to get it I would appreciate the help.
81_chapparel194
Re: Bimini top
check here on iboats under bimini tops and see if they show a parts diagram... not sure what that piece is or what it does as my bimini doesnt have anyhting like that.. is that a support arm connector or does that secure it to boat
MJG24
Re: Bimini top
iboats, ********, etc. Many online options. May try BassPro.
t8764
Re: Bimini top
The part is when you lay it down it holds the top up a little so it dosnt sit on the boat. I have looked at iboats bass pro ******** and just goggled it but cant come up with anything.
81_chapparel194
Re: Bimini top
not sure what site u mentioned that showed up as ******* but im assuming its a competitor that iboats blocks out lol but do you have the piece for the other side that you can post a pic of to give an idea what your looking for? or more detail like is it a rubber stopper or a long tubular brace or something
t8764
Re: Bimini top
0954_BIMINI_TOP_HINGE.jpgHere is the picture of the other side it is a quick release
t8764
Re: Bimini top
It dosnt have the pin it has a hole that goes around the pole and then the quick release fitting to hold it into the part attached to the boat. Kind of hard to explain but my 1st picture is the part that would go into the base mounted to the boat.
It fell into the water I was getting ready to head home and was laying the bimini down and I guess the allen key that hold it in place came loose into about 30 foot of water.
Thanks Erik
81_chapparel194
Re: Bimini top
DSCN1031.jpg ok so which color arrow points to the piece you need? sorry to be a pest just trying to help you out
t8764
Re: Bimini top
I am missing the whole thing it all fell in the drink
Thanks
Erik
