Mercruiser 3.0 Tachometer
rallm
I've got a 1995 mercruiser 3.0. When not even close to WTO, the tach exceeds 5000. How can I hook up an external tach to compare the readings to determine if the installed tach is correct?
cr2k
Re: Mercruiser 3.0 Tachometer
First off look at the back of the tach and make sure it is set for the correct number of cylinders. A small rotary switch uses a tint screwdriver.
Oshkosh1
Ensign
Get a handheld PhotoTach...works great for comparison. Just put a reflective strip on the pulley and aim!
