1996 Force 40 HP exhaust/water leak
checkeredflag
I have replaced both the head gasket and exhaust port gaskets on my 1996 Force 40hp and there is still exhaust and water escaping somewhere near the exhaust port. I cannot tell exactly where. I am unsure what to do next and want to avoid spending too much on this older motor, since I am told this Mercury/Force type motor is, but no longer manufactured. I welcome any suggestions. Motor runs fine fumes were choking it down when cowl was attached.
jerryjerry05
Re: 1996 Force 40 HP exhaust/water leak
Parts are still readily available.
There are 2-4 places the exhaust can be leaking.
Unfortunatly they are under the powerhead.
Get a parts diagram or go to boats . net and look up your motor.
Then the first thing you see is the link for the adaptor plate upper.
That's the first place.
Then look at the driveshaft housing.#33 #8 #30 can all be a leak point.
Really not that hard to fix,just time consuming.
Don't be discouraged these motors can last a VERY long time and are usually very dependable.
Mine are 24 and still going.
Fill out the profile,location??
You might be close to someone who can help.
checkeredflag
Thanks JerryJerry05. I just ordered a factory service manual off eBay. I believe it is the powerhead to adapter gasket just below the exhaust port plate area. Cannot find that gasket in the parts diagrams online or at least I haven't yet. Will wait until I see what all must come apart to replace this and then order any gaskets that I need. The exhaust plate was a pain with the lower cowl on, but I managed. Hope to separate the power head by removing the 6 M10x100 bolts, but I will see what the manual says.
jerryjerry05
One of the gaskets is just silicone.
I use Permatex,either black or blue.
checkeredflag
Found loose bolts in adapter plate and stripped threads on the 2 longer bolts near exhaust port. Repaired with Heli coils and 2 new adapter plate gaskets. Seems to have resolved my leaks. Washers on 3 of the adapter bolts were broken into small pieces. Removal of power head was not too complicated. I was able to lift it off by myself by standing in the bed of my pickup in order to get a good lift angle.
kevuda340
Having the same problem with my 40 force ( Water leak) I replaced the 2 Exhaust PLate gaskets still leaked. Removed linkage and everything to remove the powerhead, 6 mounting bolts etc. , it moves but something is still holding it down somewhere in the front. The manual mentions a hidden screw under a removeable exhuast muffler adapter?? can't find... HELP! Thanks, Kevin
