tgodliquor
- Aug 16, 2012
- 4
Hey, new to posting here as I'm a new boat owner. I recently purchased an 18ft seaswirl w/ an 850 merc outboard on it. The motor runs and I've had it on the water twice. It haden't been run since 1999 before recently. The guy before me took it to a mechanic to have some wiring fixed and he also checked the compression which was all good. My question is I know I should pull and clean the carbs because if I lean out a piston I could really mess things up, but if I've had it out and run twice and it runs nice, do I need to? Or can it wait until a winter project? Also what would you recommend to add to the fuel to make sure things are clean inside? Specific directions as to additive ratios would be appreciated. I pulled and cleaned the fuel tank and replaced all the fuel line and added an inline filter as well. Any other adviced for a new boat owner would be appreciated as well. Thanks
Todd Godfrey
Todd Godfrey
