I had problems finding ground under dash so radio is wired direct to battery ans wired to speakers works great. Two things not sure just what gauge wire I should connect to battery and then i am wanting to listen to radio with out boat on what is the easyiest way and cheapest to connect from start to finish adding 12in sub and 400 amp. I have no wiring harnes wiring each line and red power in has no fuse, is this a have to and what size do i add to this. Thank you so much
