billbert25
- Aug 14, 2012
- 2
Can someone help me with a problem on my 1976 75 hp Evinrude outboard?
While fishing last weekend it started to sputter over the course of a 15 min period but kept running. After more sputtering it died and I cannot start it at all. I have put brand new gas in it, sprayed some in the carbs, and tried several combinations of choking and not choking with warm up lever. The boat has run great for 5 years up until this point. I believe I'm getting gas into the engine but I have no spark. I tested all 3 plug wires and there is no power going to them or each coil when I try to start it. I traced power coming in all the way to the rectifier. There is a wire coming in (which has power) and 2 wires coming out (only 1 has power.) Should I replace the rectifier? I can get it for $40 but the mechanic tells me he doesn't think this is a problem. I have no power beyond the rectifier but I have power going into it.
Could there be a problem with the flywheel or its components?
Please help!!
Please help!!
