jhosea1979
- Jun 16, 2010
- 47
I HAVE GOT A 36VOLT 101# MAXXIUM. I HAVE RAN NEW WIRE FROM FRONT TO BACK NEW 60 AMP BREAKER. THE MOTOR WORKS GREAT EXCEPT FOR AFTER YOU ARE TROLLING A LITTLE WHILE AND STOP YOU HAVE GOT TO PICK THE MOTOR UP AND MANUALLY TRUN THE PROP TO GET IT STARTED. AT FIRST I THOUGHT IT WAS A BAD CONNECT HENCE CHANGED ALL OF THE WIRING FROM BATTERYS TO FOOT CONTROL. OPENED THE LOWER UNIT TO CHECK FOR SIGNS OF WATER OR A SHORT BUT NONE WAS FOUND ALL INSIDES LOOKED AS NEW. ANY IDEA WHAT WOULD CAUSE A PROBLEM LIKE THIS WOULD BE GREAT I AM LOST AND DONT KNOW WHAT TO CHECK HELPPPPP. TOURNY TOMMOROW!!!!!
