Re: 97 Force 120 Limp Mode
I know it "sounds" lik a lot between the two, but if you got the $1500 motor down to say $1200, I'd bet you come out ahead. If the other motor was something "simple", seems like the owner would fix it so he, too, could ask $1500 for his. I don't know, just throwing things out there.
You could probably find a guy local to the "broke" motor that you could pay $100.00 to go do a compression test and diagnose it for you. That way, you at least know and if spending $100 saves you a nightmare then it's the cheapest hundred you've ever spent.
BTW, does the local 120 have "oil injection"? My manual is printed in 1998 and it doesn't mention an oil pump at all. Again, I don't know for sure, but I'm still thrown a smidge by that.
