77 Crestliner
- Aug 10, 2012
- 1
I have a 1977 Crestliner 190 HP with a 302 Ford motor with an electric shift lower unit. I recently changed the tilt motor for my tilt system (1 year ago) as the 2 metal pins that go into the coupler on the motor itself broke and the motor was not working all the time. Since I changed the motor, I have now gone through 4 tilt shafts. The shaft only breaks (at the part that goes into coupler) when I push the tilt down button and the motor goes down all the way with a thump. I have since changed the solinoid and had the switches, tilt motor and coupler tested. All is good. I have been told by many mechanics that this is only happening because I hold the down button for more then a split second and I am causing the lower unit to go down too fast. They are right, as to say, if I just tap the button, the motor does not go down all the way and then tap again, it does not thump as hard or break the pin. But, sometimes it still dhas broke the shaft. When I had the old tilt motor I never had a shaft brake in 20 years. Why are they breaking so often now? Has anyone had a simular problem? Any suggestions on how to prevent this from happening so often?
