I am new to this site and this boating info. I'm sure this question is always arising but please help me out. The engine sat for 4 years and I changed plugs, lower gear lube. (There was a bit of water in it) New battery, gas with marine stablizer, alittle spray of engine starter in the carbs, Rabbit ears with water running at various pressures. (Half to almost full pressure) and it fired up on the fifth try. Not rough at all but no water being discharged out the pee hole. I assume its the water pump/impeller which I will change BUT could anyone tell me if it might be something else or in addition. Perhaps a blockage or breakage. No, I haven't taken the lower unit off yet. Your thoughts and info are greatly appreciated as my kid is screaming to get tubing ASAP and I am broke.
