i was just thinking i know that its recommended to use the correct plugs , but what if i put a hotter plug in & set the timing to 0- degrees tdc as apposed to 4 - 6 degrees on some motors with the recommended plug surely by doing this it will not have any pre detonation thus eliminating pre detonation which causes over heat & should start easier . bearing in mind that i will have to retard the wot timing too to how ever many degree i move to 0 degrees
