mahoganybd
- Sep 19, 2010
- 14
1977 85hp rude, 4cyl, recently tried boat motor in river, after it had been serviced in March. (1st time out) I left boat on trailer, and started motor, it kicked in on 2nd try. Let run for about 15mins in idle, turned off, waited 5mins, and started it up again., Unhooked boat from trailer and everytime I would but it in reverse it would go dead immediately. Tried 2 more times and it did the same thing. On th 4th try the engine just spun, and started making a clickin noise, coming from the starter. Also, noticed after looking at it the next day, that when I would squeeze the gas bulb, the gasoline would start leaking from the top carburator. Also, one of the sparkplug wires that goes into the ign. coil, came out easily when checked. When engine was running did not check to see if gas was leaking, althoug I didn't smell anything. But engine would surge at times. The marine tech, had put a carb kit on and a high speed jet plug; also mentioned that I needed a stator, and timer base, but they did demonstrate that it ran.
Would like to try to do these thing myself, but not sure if its something that I should tackle, or get some help, or do nothing. (Scrap)
