1998 40 hp mercury
rrf
I wound a rope up in my prop when ideling in forward. It was hard to pull lever back to neutral. Now motor jumps in reverse. Seems to engage fine under low power but jumps under moderate throttle.
Dave1027
Re: 1998 40 hp mercury
What do you mean by "Jumps" in reverse? My first thought is you probably broke or bent the shifting linkage.
rrf
It chatters like the cogs are not fully engaging. It works ok under mild throttle. The lever in the top of the engine seems to be moving all the way. It was a little hard to shift into neutral when the rope was tangled. I wonder if the rod that goes to the lower unit is light enouth that it would bend easily.
