my 1967 chrysler o/b has been running way too rich. When i pull it out in the driveway and hook the water up to it in a barrel to get her started she takes a minute to start (which is somewhat normal since its so old) but the idle is a little choppy and will die out if i dont give it a little gas.
The problem is: when i start to throttle up, the rpm's dont quite follow i have to slowly open the throttle til its WOT. then itll start roaring and sounding like the little beast she is. BUT, there is soo much smoke its ridiculous. Also, the side of the carb is spitting fuel out of the peep hole like a cut artery, this happens almost at any throttle position.
I have already replaced:
-Spark plugs
-Voltage regulator
-ALL fuel Lines
-Fuel pump diaphram
-pulled apart and cleaned the carb
-dropped the lower unit and completely cleaned and relubed.
-replaced the terminal on the Magneto
If anyone has ANY ideas, it would be much appreciated. Ive been running 50:1 mix so i dont think its a problem unless i need to go get fuel with no ethanol and a higher grade 2 cycle oil. Please help! thank you in advance!
-Spark plugs
-Voltage regulator
-ALL fuel Lines
-Fuel pump diaphram
