Idle and starting problems after pertronix install
astuckey
Hi, I have a 4.3 cobra, that has had idle problems, since I installed the pertronix ignitor 2 module. The timing is set correctly, and the ignitor 2 module is hooked up to the alternator, at a switched source. Interestingly, the problem only happens when the engine is not completely warmed up yet. Also, I looked at the magnetic pickup, and the ignitor module, and both had wear on them. It looked as if there was no gap between the magnetic pickup, and the ignitor. I GENTLY applied pressure to the ignitor to try to bend it back, and got a slight gap. Same problem. I called pertronix, and they said that the slight, or no gap wouldn't affect the preformance, it would only cause the pickup and ignitor to wear. I put an inline spark tester on a few cylenders, and the spark was sometimes strong, sometimes weak, and sometimes, no spark at all.
Has anyone else had this problem?
Also, I have a prestolite, IBM 7021 distributed, and a ignitor 2 #91563B
Any help would be greatly appreciated!
Thanks
astuckey
Re: Idle and starting problems after pertronix install
Anyone?
Levinz11
So once the engine is up to temp, everything is fine? I'd say screw it and run it.
keith2k455
What about the coil? did you upgrade the coil as well?
I also checked Pertronix website and they claim that at low rpm (around idle speed) your dwell control is less than that with standard points. May be no problem at all, as long as it starts fine.
http://pertronix.com/prod/ig/ignitor2/default.aspx
astuckey
That's good to know, however, I do have starting problems. I will check out the dwell, with a dwell meter. Also, I have the flamethrower 2 coil.
Howard Sterndrive
did it idle well with points?
triple check the firing order of the wires if any were removed.
Is the flamethrower getting 12V, or fed from the old resistor wire to the old coil?
(I'm not sure which is correct either - despite reading a gazillion different discussions on that - eventually putting my Flamethrower on eBay because who knows?)
personally, I'm a lover of the stock coil setup on a boat.
9000V is all your plugs probably ever require during operation if properly gapped.
astuckey
I am pretty sure it is a problem with the adaptive dwell control of the ignitor 2. At idle, it reads below 10, and the book says 39?2. I found out some stuff about the ignitor 2 having this problem, with some 6 cylinder engines. I will call pertronix....again.
keith2k455
Good luck ... If it gets too frustrating you can always send it back and get a mallory unilite
bruceb58
Or put your points back in or chuck the whole distributor and put in a Delco EST.
Your problem is why I would never put Pertronix in.
astuckey
Ya, I'm considering swapping it for the ignitor 1, I did some reading and apparently it only happens with the ignitor 2.
Gpayne
Not sure about marine usage, but I had an old antique tractor that I put an Ignitor 1 kit in. Best money I ever spent. Started, idled, and ran 100% better. Plus, no points to mess with again. As per Howard's post, primary resistance is critical with these units. If memory serves, they require 5-8 ohms resistance, same as points. You can either use a standard coil with an external resistor, or a Pertronix Flamethrower coil with a built-in resistor. That's what I did and I never had any issues out of my old Massey.
