crawdadric
- Nov 29, 2005
- 88
1985 Sea Ray SRV 300 Twin 5.7L Mercruisers with Alpha 1 outdrives.<br /><br />Question 1 - I'm replacing the shift cable and need to replace the lock wire on the shift slide assembly. Does anybody know the thickness of the wire and where to buy it?<br /><br />Question 2 - Which direction do you turn the cable nut to remove the cable from aft of the bellhousing? The reason why I ask is because I've read the old style cable was mounted forward of the bellhousing so the thread would be right hand looking forward of the bellhousing looking aft. To convert to the new style cable you have to run a tap through form the forward end. This would make the thread left hand, if you were aft of the bellhousing looking forward. Confused yet? I'm having a hard time wording this right. My cable tool started to round off the nut edges, so I want to make sure I turn it the right way.<br /><br />Thank you in advance....
