Aluminum Tongue
billfish_1
The tongue on my Magic Tilt trailer has rusted out and i need to replace. The old tongue was 11 gauge (6' x 3" x 3" x 1/8") galvanized steel. I have a 6' piece of 3" x 3" x 1/4" aluminum that I thought I might be able to use which would avoid rusting out in hte future. Anyone know of any problems using this.
robert graham
Re: Aluminum Tongue
You talkin' 3"x3" Channel or Angle or Square Tube?...A lot would depend on the weight of your rig/tongue weight, but generally the aluminum should work fine.
Thalasso
Re: Aluminum Tongue
What is the tinsel strength of the aluminum compared to the steel?
cribber
Re: Aluminum Tongue
Generally when Aluminum is use to build a trailer its from I-beam type stock. If what you have is a single axle trailer and this is 1/4" walled 3" square tubing you should be okay depending on what your total tongue weight. Pictures go a long way to help get the right answer for you question.
Re: Aluminum Tongue
depending on the aluminum, between 18ksi and 30ksi, where common steel is between 30ksi and 36ksi
billfish_1
Re: Aluminum Tongue
The trailer is a tandem axle, the boat is 3500 lbs with a 200 lb tongue weight and the aluminum is 3" x 3" square tubing. I am just wondering why they don't use aluminum to begin with to avoid this rusting out
Re: Aluminum Tongue
Because aluminum costs 2 x that of painted steel. the average person would not want to pay the higher prices. and this way the trailer company can keep costs low and still make a profit.
Thalasso
Re: Aluminum Tongue
Mine is a triaxle aluminum I beam with a galvanized tounge. I don't think with those tensile strength numbers that the aluminum would hold up as long.
Re: Aluminum Tongue
the beam strength for deflection is based on the thickness of the vertical section and the material strength as well as a few other factors. generally aluminum has a better strength to weight ratio than steel. it has to be twice as thick, however will still be lighter than steel.
loose rivet
Re: Aluminum Tongue
I'd be as concerned about overall strength of the aluminum tongue as well as dissimilar metal issues or electrolysis.
dingbat
Re: Aluminum Tongue
Very misleading information and not appropriate for the discussion at hand.
In dealing with a tongue you’re concerned with the modulus of elasticity of the material. Google "Young's modulus" for an explaination.
Aluminum has a very poor fatigue limit under cyclic load which precludes its use as a structural component in a cyclic application and thus, aluminum trailers with steel tongues.;)
As someone who participated in a joint research project with Alcan and GM back in the mid-80’s, I don’t think I’d be using an aluminum tongue on a trailer anytime too soon, or any othere structural componet on a trailer.
Thalasso
Re: Aluminum Tongue
Then why do they build aluminum trailers if that's the case. The I beams down the side are structural. Usually the cross members are galvanized.
dingbat
Re: Aluminum Tongue
Marketing. A solution to a problem that didn't exist. Google crack aluminum trailer ;) Not to mention that they flex like silly putty. Great hull support :rolleyes:
Thalasso
Re: Aluminum Tongue
Don't know how to take this response but i can tell you for fact that there are thousands of them out there.They can't be all that bad. Heck there is railroad cars made out of aluminum.Some of the best made are aluminum. Owens and Sons, Mayco and so on.
Re: Aluminum Tongue
I will agree that ferrous materials handle cyclical loading much better than non-ferrous materials. you can only bend a beer can so much. Titanium is even better for cyclical loading. Maybe we should have trailers made from titanium alloy :facepalm:
The question was asked specifically on comparing tensile strenghts of each material. Not, what is the fatigue limit
However if you know and understand the material properties of anything, have the training and experience - you can build anything. Knowing the UTS is only one step. keep the design well below the S-N curves is another. Understanding the deflection and the induced stresses is yet another.
Many manufacturers of aluminum trailers use aluminum on the tongues as well. Most are built ultra-conservatively to minimize deflection.
briangcc
Re: Aluminum Tongue
I'm surprised no one has mentioned a little issue with mixing steel and aluminum....Galvanic corrosion. Where the two dis-similar metals meet, there will be a reaction - RUST.
Best bet would be to stay with a steel replacement tongue.
Re: Aluminum Tongue
I wouldn't second guess the manufacturer unless you have the knowledge and experience to know what you are doing, and since you asked here, I am guessing you you don't.
I would use the same material as original unless you need to beef it up or lengthen it fo some reason. and I agree with the concern of galvanic corrosion from dissimilar metals.
UncleWillie
Re: Aluminum Tongue
After you price the Steel and Aluminum stock, you may change your mind about the steel issue.
The replacement will likely outlast the boat. Are you really planning on keeping it another 20 years?
dingbat
Re: Aluminum Tongue
The Chevy Vega received the 1971 Car of the Year and 1973 Car of the Year in the Economy Class from Motor Trend; Best Economy Sedan in 1971, 1972 and 1973 from Car and Driver and the 1971 award for Excellence in design in transportation equipment from American Iron and Steel Institute.
They sold thousands of Chevy Vegas too. :facepalm:
"Aluminum" railroad cars use a steel superstructure.
Best is a subjective term. Best at what? Myco builds both aluminum and galvanized trailers. Obviously, neither material is the ?best? for everything.
I guess dumb questions deserve an answer as well. :rolleyes:
As someone who possesses those skills, I will agree that it is possible to design a robust, aluminum framed boat trailer but it would not be an economically viable product for the consumer market. The premium you would pay for a properly made aluminum trailer would never be paid back in fuel savings. Aluminum is more corrosion resistant but to what end? The average boater keeps a trailer for 1/3 of the expectancy of a galvanized steel trailer. Where is the value?
Again, ultra conservatism in design costs money. Where is the value?
Thalasso
Re: Aluminum Tongue
No galvanic corrosion on them.No galvanic corrosion on my 7yr old aluminum trailer
Owens and Sons builds nothing but aluminum trailers.You failed to mention them along with Mayco
Apparently you don't like aluminum trailers?
It's not about fuel savings, it's about maintenance. No rust like using steel. I guess you would rather have a steel trailer for saltwater use?:facepalm::facepalm:
