Its a 1991 alpha one
To check the raw water pump, you're going to need to remove the lower unit of your drive and pull apart the pump housing to inspect. At that point, it might be worth it to just replace the impeller with a new kit. Do a search on here and/or youtube and you'll get plenty of instructions/how to's for doing it. It's not a bad job, just take your time and be thorough.
As stated a couple of times already, 170 to 175 is normal for a raw water cooled engine with a 160? thermostat. If the outside temp and the water temps are really high you may see up to 180?. But, if it goes higher than that, you have a problem.What is the Max temp u can run these?
