Re: Electric problem battery only pontoon, batteries charge but no radio or lights
A general electrician is probably more at home with residential and commercial AC wiring and doesn't have a clue how a boat is wired (which is low voltage DC). You missed my point regarding disconnected wires so I will make this a step by step list. You don't need any tools for this but you need to apply some deductive reasoning and follow instructions.
1) Locate the fuse panel
2) The fuse panel usually has a red wire (larger than most of the other wires you so connected to that panel). That wire feeds 12 volts INTO the panel from JUST ONE of the four batteries. A black wire of the same size is the ground wire for the 12 volt system and also needs to connect to the same battery as the red wire.
3) Follow those two bigger wires (or at least the red one) from the fuse panel back to where it connects to one of the batteries. If you find it disconnected that's why none of the 12 volt accessories work.
4) Follow the larger black wire from the fuse panel ground buss or a separate ground buss back to where it connects to one of the batteries. If it is disconnected that's also why none of the 12 volt accessories work.
5) If either or both of those wires are disconnected, they need to be connected to ONE of the batteries. The best one to use is the one that has the black wire from the electric motor.
6) If you find that one of the larger wires you traced from the fuse panel was connected to a battery other than the one I mentioned in step 5, then attach the disconnected wire to that battery.
7) The red wire that feeds the fuse panel should have a fuse or circuit breaker in it within six inches of the battery. That's another clue for you. See if you can find that wire. If you find it, and the wire is connected, check that fuse or circuit breaker. If it is open then replace it or if a circuit breaker is used, press the reset button if it has one.
8) Here is a summary of the above:
The red and black wires feeding the fuse panel need to be connected to one battery.
There should be a fuse or breaker in the red wire within six inches or so of the positive post on the battery to which the red wire
feeding the fuse panel is attached.
The fuse or circuit breaker must be good
The ground lead from the ground buss must be connected to one battery via the larger black wire.
If these checks and corrective actions are done correctly the 12 volt accessories should work.
