Re: 150 force I THINK SOMETHING IS BROKE please give me good news i have pics.
It was not a lean run due to carb problems that caused the broken rings. Those stock pistons with the semi-keystone top ring are prone to breaking them for no particular reason So, leave the carbs set where they were.
That is a 3.375 bore engine. look at the tops of the other pistons. If there are no marks in them then it is a good bet that they are not oversized. To be certain though, borrow a caliper and measure the bore. It should be exactly 3.375 or 3 3/8 inches. If so, order a standard sized piston.
The arm is called a connecting rod. it is attached to the piston by the wrist pin. The wrist pin is pressed into the two keepers on eother side of the needles. You need to press out the existing wrist pin. If you buy a Wiseco piston, it will come with a new wrist pin and rings.You will need to buy a bearing kit also. This is to say that if you buy a Wiseco piston, it will not matter if you damage the keepers or needle bearings. Thus, you can hammer out the wrisrt pin.
Your photos show a couple of nicks at the exhaust ports and there are still a couple of small imperfections in the cylinder wall BUT:They do not look to bad and you will most likely get adequate compression and very close to normal performance. It is not necessary to put anything on the cylinder walls except a coating of TWC-3 oil for assembly. Coat the rings and piston skirt too.
One hint: If you should need to hone a cylinder again, run the hone slowly and move it in and out at a rate so that the hone marks in the cylinder cross at about a 60 degree angle. This aids in "seating" the new rings.
Before you assemble the piston into the block, test fit the rod cap on the end. It only goes one way and if installed incorrectly, will result in even more engine damage. Use grease to retain the rollers and cages. After all are in, replace the cap and just snug it. Test the ground flats on the rod to make sure thay are even and turn the engine a couple of times by hand. Then, tighten the rod cap bolts to 190 INCH pounds.
The rod is a very close fit between the crank cheeks and if off center or cocked slightly it simply will not go. Here is where it may fight you and you will need to be patient. Make sure it is perfectly horizontal and using a long rod, wiggle it back and forth to center it between the crank cheeks.
